Question how to undervolt a gtx 980 reference card?
sergioalbertocmarin
76
4
18,535
i wanna know if theres a way to undervolt this card to keep the wattage usage lower.
i was planning to use msi afterburning but when i tried to do ctrl+F it doesnt show the custom curve for the voltage
perhaps someone can help me out with this.
Did you enable voltage control in afterburners settings? Its disabled by default. I believe you can tweak the voltage a bit on maxwell cards. Setting a power limit would probably be the more practical way to limit the amount of power the card draws however.
I enabled it idk if it's the same as core voltage for voltage control? Sadly with Maxwell cards I cant.do the curve customization as you can with 1000 cards edition , I have unlocked core voltage and power limit now I wanna know if this is what I need and how to use it properly without losing much performance but saving energy consumption and if performance is gonna be lost I don't mind a few fps.
Thanks for the assistance
