So I have an ASUS VG248QE I've had going for 7 years now. I like to use the built-in speakers for music when away from my PC. I run it through a 3.5mm splitter to get audio to both monitors. However, when I switched to using Display Port from DVI since I upgraded my PC I lost audio from the 3.5mm jack. I tried using the DVI and I get the 3.5mm jack to work again.
Is there a way to get the monitor to use the 3.5mm input while also using DP? It seems to auto-switch depending on if I use DVI or DP but I'd like to force it to just use the 3.5mm input.
