How would a computer build like this work for gaming? What about water cooling? Any suggestions? Overclock able?
mscrawford1203
6
So I am building a brand new gaming pc and wanted to see what people may say about this build and how well it would run, not being overclocked. Would water cooling work better then a fan most likely for this build if I were to be overclocking, if so what type of water cooling system/fan would work. What are some speeds you guys overclock at? Do you guys have any other suggestions?
PC Build Link: PC Parts
Umm 7200/5400 RPM (revolutions per minute) is in regards to the speed of the physical disc's spinning in a Hard Disc Drive. An SSD has no spinning disc's, needs no RPM, it's basically just ram in a container. No moving parts.
The TT Smart series isn't that good. Tough yes, smart no.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($193.25 @ OutletPC)
Motherboard: MSI - B350M PRO-VDH Micro ATX AM4 Motherboard ($71.49 @ SuperBiiz)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory ($169.99 @ Newegg)
Storage: Crucial - MX300 275GB M.2-2280 Solid State Drive ($89.99 @ Amazon)
Storage: Seagate -...
I'd suggest a few changes
1. Get a 7200 rpm HDD
2. Your PSU is a little overkill. Won't hurt anything, but you could EASILY get by with a 450-550W range PSU
3. Instead of considering an additional $100+ on CPU cooling / overclocking, see if you can bump your GPU up to a 1060 maybe? The priority is GPU over CPU for the build you're looking at.
# 1 & #3 might be a smart idea to do. My PSU is a 750W because it was $10 more that the 550W that I was going to get and thought that a 750W would leave me room for upgrades and stuff.
So I checked and a 7200 RPM HDD would be slower than the 5400 RPM SSD that I have selected.
I clicked the wrong hard drive!!! I am so sorry, you are completely right about that i meant to get a 5400 RPM SSD. You are right with what I have on there a 7200 would be better.
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Newegg)
Video Card: PowerColor - Radeon RX 580 8GB Red Devil Golden Sample Video Card ($404.98 @ Newegg)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ Amazon)
Optical Drive: LG - GH24NS95 DVD/CD Writer ($20.73 @ OutletPC)
Wireless Network Adapter: Gigabyte - GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter ($38.99 @ B&H)
Other: SAMA Maxcool-W-15LEDLight White Computer Case ($44.98 @ Newegg)
Total: $1154.38
Generated by PCPartPicker 2018-01-24 23:29 EST-0500
Your right, this all has been very helpful.
