Been trying to figure out how to get power from an ATX PSU to this board. I bought a adapter that was apparently meant for the boards on HPs, well it doesn't work. I have tested the psu to see if it works with the 4 3 pin (Clipside) with a wire, psu turns on. Also when I plug the old psu in the pc boots, so its just the adapter I'm trying to find so I can provide the power, the reason is I installed a 1060 and it needs power.
Here is the motherboard :
View: https://imgur.com/a/Rm7LINP
Here is the adapter I bought and did not work : https://www.amazon.com/dp/B06XW7RWNH?psc=1&ref=ppx_yo2ov_dt_b_product_details
Here is a adapter I am thinking of buying and testing : https://www.amazon.com/COMeap-Power-Adapter-Motherboard-13-3-inch/dp/B08M5BZ6P8/ref=sr_1_8?crid=1UU338BKGMNH2&keywords=24+pin+to+6+pin+adapter+Hp+280+sff&qid=1674531455&sprefix=24+pin+to+6+pin+adapter+hp+280+sff,aps,88&sr=8-8
I came here because since this pre-build is old, and is proprietary, I at least wanted to see if someone had some info on this.
Help is appreciated, thank you.
P.S. Im just using this PC as a Emulation machine.
