G
Guest
Guest
Archived from groups: comp.sys.hp.hardware (More info?)
Hi Folks,
I need to do a small project on HP-UX, and I have an HP-9000 C110 system
that I can use for this purpose.
Unfortunately the system's internal HD is only 2.2 GB, and I need it to
be at least 12 GB for this task. I looked up the number of the internal
drive, and it's a 50 pin SCSI-2 SE (single ended) model.
I have an 18 GB, 68 pin, SCSI-3, Ultra 160 SE drive, and a 68 pin to 50
pin cable adapter. I was wondering if anyone knows whether there's a
limitation that would keep this adapted drive from working properly in
the C110.
I could just plug it in and see what happens, but I wanted to see if
anyone knew whether this would work in advance.
Thanks for any pointers!
-dreq
Hi Folks,
the C110.
-dreq
