L lab 52 Honorable Mar 28, 2012 1 0 10,510 Mar 28, 2012 #1 and I cant get it to work on my lenovo pc. The pc is in another room about 8-10 yards away. The correct connection shows up and it is scanning like its looking and the task bar shows green for a few seconds and then says it can get a connection
Emerald Titan Aug 28, 2005 15,925 10 70,865 Mar 28, 2012 #2 which OS? aree you using the netgear software or windows to control the wireless? Upvote 0 Downvote
