[SOLVED] I need help choosing a Motherboard for mining ?
Sep 3, 2021
8
Hi Friends
My brother has asked me to survey for him to get a mining motherboard
He wants to start it and already has ordered 9x RX 580 XFX Brand
I have had my search and there are some common models but they have mentioned that they support up to 12x GPUs but i have seen that many people has problems with the maximum of 8x Gpus
I want to run it on windows instead of any other OS!
the models I found which can be found in my area :
TB360-BTC PRO 2.0
ASRock H110 PRO BTC
BIOSTAR TB250
Thanks in advanced.
One of the Biostar boards has the option for 6 GPU's, while the ASRock has the option for 13 GPU's. You're going to be fine with either boards, though keep in mind that you shouldn't be getting the BIOSTAR TB250 due to limited slots and you having 9 cards. I don't know where you're seeing it support 12 GPU's but there are only 5/6 physical slots on that board. The other two have more than 5.
