Question I need help my pc won't post.
Jul 10, 2022
4
So today I bought all new pc parts:
Motherboard:H510M H rev 1.3
Cpu:I3-10105f
Ram: 2x 8gb teamgroup 2666mhz ddr4
PSU:ZM500-LX II
And I have a couple of gpus.
My problem is when I try to turn it on,the fans start spinning for like 6-10 seconds, then they stop for a moment and start spinning again and stop again etc.I don't have a led on the motherboard. I tried replugging cables, taking out the cmos for 20 minutes, reseating the cpu, tried different gpus, tried it without a gpu, different ssds and hhds and even with no storage. Tried switching the ram slots, tried one ram at a time with both slots and both ram sticks.Tried different outlets and different power cables. Tried turning on the pc with a screwdriver without a case.All this to no avail.What should I do?All the part except my gpus are new and even those gpus work in other pcs.
The weird thing is when I take out my cpu the fans wont stop, it won't restart.Of course it doesn't post that way, but I'm thinking it's a faulty cpu or motheboard.Sadly I can't test those components because those are the only cpu and mobo I have. Any thoughts? Can someome help me find the core of the problem?
and what might they be?
PSU:ZM500-LX II
How old is the PSU in your build?
Brings me back to the make and models of the GPU's.
Inspect the CPU socket for any bent or broken pins.
Motherboard:H510M H
https://www.gigabyte.com/Motherboard/H510M-H-rev-13#kf
Is this the board you're working with? If so, what PCB revision are you working with?
PSU:ZM500-LX II
Motherboard:H510M H
rev 1.3
I have a gts 450, gtx 950 and a gt 430
I inspected it and I didn't see any broken pins.
