[SOLVED] I need help Upgrading my system.
Dylan Havell
17
Hello,
I am currently looking to be able to play Mount and blade bannerlord. I have a low budget of 300 dollars for improvement. Please see my current parts below. i believe all i need is a new graphics card as i purchased everything this year aside from the gpu and psu which were purchased in 2017.
CPU: AMD RYZEN 5 2600 3.4GHZ 6-CORE W/ Cooler Master Hyper 212 RGB Cooler
Mobo: Asus TUF GAMING Xx570-PLUS (wifi) ATX AM4
RAM: 2X 1GB GSKILL AEGIS DDR4 - 3000
Storage: Samgsung Evo 860 500gb.
PSU: 500W Unknown brand
Graphics: AMD Ryzeen HD 7770.
If your ram is actually just 2GB you need to upgrade that first. You need atleast 6GB to play the game according to the specs requirements. I would spend the leftover money to buy psu and/or gpu. You should buy 8GB ram which will be around 50$. You should also consider buying a PSU from a known brand aswell.
