Question I need help with decision between these 3 Monitors.
Jun 11, 2023
Hello tom's HARDWARE community,
I need help deciding between these three Monitors.
For INFO they are all the same price in my Country and I am not savvy enough to make a decision based on specs.
The picture quality is more of a priority for me then the latency, but I still don't want to end up with a ghosting or a laggy mess.
It would be mounted on a Monitor arm, so the base size doesn't matter, nor the thickness.
My budget is 300 Euros and I want at least a 100Hz, 3440x1440, 21:9, 30" Monitor, if you have others recommendations outside of these three models please let me know.
  • AOC U34E2M
  • LC-Power LC-M34-UWQHD-100-C-V3
  • Samsung ViewFinity S5 S50GC
Thanks for all the help ahead of time.
Kind Regards
frodopls
Would it really make that much of a difference in picture quality?
If you have a store near your location, you might want to see a VA panel and an IPS panel up front.
Looking at the specs to all three monitors, they are all VA panels. If you want good picture quality you would need to look at IPS panels.
in my Country
Where would that be? Do you have a preferred site for purchase?
Thanks for the reply, the preferred site of purchase is This one.
For an IPS panel I need to add another 50-60 Euros which is already stretching the budget.
