first off heres my system specs and worth noting I'm not on that pc since its not working
CPU: FX-8370
GPU: XFX RX 460 4gb single fan
MB:MSI 970 gaming
RAM: 8gb ddr3 2133
PSU:500 watt
CASE: raidmax ninja 2
HDD: 1tb ED green power (old and is now formatted)
ok so to start it turns on and the HDD activity light doesn't work even tho the HDD is on, I know it works tested with other machine.
GPU works as it should in the other machine to
the PSU works and is powering the machine I'm typing on
I tested the MB with an other CPU:FX-4350 and it still did the same thing
I cant test the CPUs with an other MB since I don't have an there AM3+ socket
I cant test RAM either but it was working fine right before it crashed
as did everything tho so I cant say that it works
I tried cables and almost everything oh it doesn't post btw it turns on lights and all no HDD activity light and no post but again the HDD works so I don't know what is going on
I just want help understanding if its broken and I need to buy new parts or its something I can fix
also I did clear Cmos and removed the little battery and cleaned everything
thank you for helping
CPU: FX-8370
MB:MSI 970 gaming
RAM: 8gb ddr3 2133
PSU:500 watt
