Question I4790k Thermal Throttling overheats. Help ?
bba
5
If your CPU gets up to 100c temps pretty quickly, then it's very likely the new cooler isn't seated properly, or the thermal paste hasn't been applied correctly.
You may need to check these things and re-install the cooler.
Looking at it now you may be correct. looking the the picture i think the radiator and fan need to be switched
