Hello everybody,
I have recently bought a laptop with i510500H cpu and GTX 1650 Ti. To test the machine and see the performance I installed XTU, Cinebench, AIDA64 and Timespy. One thing I noticed while I was running the stress tests and benchs is that Current/EDP Limit Throttling and Power Limit Throttling is almost always active. Even in idle without any loads these are coming on and off in intervals of minutes and while under load, they activate and never goes away. My concern is that when CPU is loaded (all the same in benchs, games and stress tests) Max. Core Frequency decreases from 4.2 GHz to 3.6 GHz and when I monitor clock speeds on AIDA64 its is confirmed that clock speeds does not reach anything higher than this value. The specified Max. Turbo Freq. for this processor is 4.5 GHz, and I know that i will not receive all of this but getting 3.6 GHz seems too extreme. Below I attached 2 images while laptop is idle, and under load of Cinebench. You can see what I described above in graphs of XTU.
Another thing to mention related to this case is that nothing is even near thermal limits as you can see. In about a week I played R6 Siege, COD Warzone, SC2 and Cities. Temperature of CPU almost never exceeds 80 C.
Idle: Intervals of Current/EDP Limit Throttling and Power Limit Throttling
Underload: Continuous Current/EDP Limit Throttling and Power Limit Throttling, and decreased Max. Core Freq. although CPU is utilized 100%.
Based on what I found on internet (actually not much) I thought this is an issue of electrical limits, and I came up with an idea that if I undervolt on BIOS maybe it is solved, but no. I undervolted using step decrease ((-) 5, 10, 20, 30, 40, 50mV) and behavior of these two throttlings does not change. However, I must add that after undervolting performance scores of the machine is increased in Cinebench independent of temperature values. Temperature values are still the same, even under serious loads of benchs I mentioned in the begining, it tries to hold it below 80 C.
So friends, I really need help to figure this out. I seriously suspect this is something to do with motherboard, cpu relation or something interfering with circuits, I do not know.
Thanks in advance!
Edit: I perfomed isolated stress tests of CPU, FPU & Cache on AIDA64. In CPU alone test frequency reached 4.2 GHz, in FPU and Cache alone tests it hangs around 3.5 GHz. Might be a useful piece of info.
Thanks in advance!
