Hi,
I bought a Lian Li GALAHAD AIO 240 RGB, a Lian Li lancool II mesh RGB black tempered glass ATX case that comes with 3 intake fans in the front and I also bought a 120mm exhaust fan for the rear.
How would you setup the AIO fans, intake, exhaust? I do not have the products already but I will tonight. I planned on installing the radiator on top with the 2 fans but idk if they can be switched around and all.
Also the case 3 front fans are moveable. Is it better to have more intakes than exhausts ? Or is it bad to have too much intakes?
Thank you.
Thank you.
