Hello everyone,
I recently bought a second-hand i7-8700 processor and it's worked fine for a few weeks until recently, where I noticed the PC dumping out lots more hot air than usual, causing my room to be seriously hot and uncomfortable to be in.
Upon further investigation, the CPU temperature was reaching 80-90 degrees while gaming, resulting in it downclocking automatically to about 3.6ghz on all cores, not ideal.
(power limit throttle issue) Initially, I wanted to achieve the 4.3ghz turbo boost consistently on this CPU, so I installed Intel XTU to find that the CPU was "Power Limit Throttling", as a result I changed the Turbo Boost Power Max to Unlimited as well as the Turbo Boost Short Power Max to Unlimited, this fixed the power throttling. I'm unable to change power settings within the BIOS (or I just can't find them) because my motherboard doesn't support overclocking, so this setting will have to do unless you know any better alternatives.
(temp issues) Now, temperatures are regularly hitting this 80-90 degree mark even when doing basic computing tasks, which is not ideal. resulting in the fans speeding up loudly. The CPU consistently runs at the 4.2-4.3ghz mark now, which is great and as I expected but not with these unsettling temperatures. When I open Opera GX for example, the temperature will spike up rapidly to around 80 degrees, which certainly isn't normal for a web browser. This is also the case with other basic computing tasks. When idling, the CPU seems to jolt around 40-50 degrees too.
Any help to reduce these CPU temps would be greatly appreciated.
Specs of my PC:
| Corsair Carbide Series® SPEC-04 Tempered Glass Mid-Tower
| ASUS ROG STRIX B360-F GAMING
| Intel(R) Core i7-8700 @ 3.20GHz
| upHere Black CPU Air Cooler w/ 4 Heat Pipes + Dual 92mm PWM Fans
| x6 Corsair ML120 Magnetic Red LED Case Fans
| x2 Patriot PSD416G26662 16GB DDR4 2666MHz (32GB Total)
| Intel(R) Optane M10 16GB
| Corsair Force MP510 NVMe 500GB
| x2 Seagate Barracuda 2TB 7200RPM
| EVGA NVIDIA GeForce RTX 2080 XC GAMING 8GB GDDR6
| Seasonic B12 BC Series 650W 80+ Bronze Non-Modular
🪟 | Microsoft Windows 11 Professional 22H2 x64
I've attached a picture of Intel XTU below.
Specs of my PC:
