Hi all,
I recently moved my AiO from the top of my case to the front as this provides much better airflow for my case.
Before this I was idling around 50c and so also redid the thermal paste just to be sure and really tightened fully the connector so it had good contact.
After this I managed to idle at what I had initially hoped for around 35c-40c with my maximum on games never exceeding around 80c or in most cases barely touching 70c.
I was more than content with this and so left it as it was, if it ain't broke you know however it has now seemingly gone back to idling at 50c. I didn't touch anything, hardware wise and have no software changes between two days ago and now that would cause that, in fact I think I have no changes at all.
I tried once again to reseat the cooler, redid the paste. I don't really want to go around ripping everything up again because I only just got it working perfectly so I thought I should ask here first before doing anything rash. Currently my Core Temp is saying as I type this i'm floating from 55-45 then popping back up to 55 again. As I said 2 days ago this number was 35-40 and I have no obvious causes to reverse/fix so I am at a loss as to anything blatantly obvious but would of course be delighted if someone could show me I am just being dumb and it is an easy fix 😀
Basic specs:
CPU: Ryzen 7 3700x
GPU: Nvidia RTX 3070
Mobo: B550F
Cooler: MSI coreliquid 360r (I know maybe it isn't the 'best' cooler but my trouble is mainly that I already achieved what I wanted and it's now reverted or something)
Of course I can provide more information if necessary, thanks in advance.
Basic specs:
CPU: Ryzen 7 3700x
Mobo: B550F
