Question Idle/workload temps of Ryzen 7 9700X ?
seyarazim
9
Hey so I just switched over from my old 9th gen intel to the Ryzen 7 9700x on a Gigabyte B650 Eagle AX and I've read multiple times that AMD runs hotter then intel but I just wanted to double check if these are ok. At idle Ryzen master says its sitting at 45 degrees C which I think in HWINFO thats the CPU Die Average and the cores sit in the low 30's/high 20's. I am using a Noctua NHD-15 with the offset mount for AM5 the 3 images are when idle, one is while downloading and 1 is with cinnebench r23 multi core test is running.
Here is the imgur of 3 images
any help with this would be great because I was thinking of undervolting/and increasing the PPT but I am worried about the temps
Edit- I also want to mention and check if this is normal but the CPU feels a lot more spikey then intel for example when i own chrome the PPT cores and temps all spike for a second then go back to normal, same with pretty much doing any task i think this might be normal but wanted to double check
