So this is a weird one, on my Aorus Z390 Pro there are 8 fan headers.
CPU_FAN
CPU_OPT
SYS-FAN1
SYS-FAN2
SYS-FAN3
SYS-FAN4
SYS-FAN5_PUMP
SYS-FAN6_PUMP
I am using 9 fans in my CoolerMaster H500M case, with 2 of those fans being part of a Corsair AIO, so those 2 are not directly plugged in the motherboard. However, if I do decide to populate 7 or 8 of the fan headers, some fan(s) will either stop working or I lose control over them within the OS (including the BIOS).
I have tried individually connecting the fans, rebooting and seeing the results and up until 6 fans, doesn't matter which fans or which headers they are, they work. But as soon as I plug in a 7th and/or 8th, one or more (up to 3 from my experience) fans will either stop working altogether, or I lose control over their speed from software.
Now, since I have checked every header and every fan individually, I can confirm that neither any fan or header is faulty. So what could the issue be? There should be plenty of power, all of these tests were run at the pc running idle and the PSU is 750 watts.
The full specs are:
Aorus Z390 Pro
Intel Core i7 9700K
Gigabyte RTX 2060 Super OC Windforce
2x8GB Corsair Vengeance RGB Pro 3200MHz C16
Sabrent Rocket 1TB NVMe SSD
WD 1TB HDD 7500RPM (Green, i believe... its old)
Seagate Barracuda 3TB 5400RPM
CM H500M case (includes 2xMF200R + 1x140mm CoolerMaster (non rgb & non LED) fans)
Cooler Master MF120R fan
Corsair Hydro 100i RGB Platinum AIO (with included fans)
3xBlue LED 120mm case fans (from my old case) rated at 0.45 amps
Corsair HX750i 80+ Platinum PSU
I also have a wifi card, a PCIe to internal USB 3.0 header card, and.... thats it, as far as I remember and can see... I like to load up my stuff well xD
Anyways, with all of these components, the PSU should have no problem powering all the fans, I even had my old GTX 750 Ti in there for a while and again, power was no issue. So why could my fans be acting up like this? I can still run all of my fans, as I have a 10 port PWM fan controller powered by sata, which I plugged the 3 blue LED fans into and now they run fine, but at full speed without control (they are DC fans, not PWM). It's not a big issue, my temps are just fine even in the heat of summer, just this behavior is strange and new to me, I've never come across such an issue before.
Thanks for any tips in advance!
CPU_FAN
CPU_OPT
SYS-FAN1
SYS-FAN2
SYS-FAN3
SYS-FAN4
SYS-FAN5_PUMP
SYS-FAN6_PUMP
The full specs are:
Aorus Z390 Pro
Intel Core i7 9700K
