Question If I buy this AIO CPU Cooler, will it fit the front top of my PC super tower case or its TOO BIG?
SeriousGaming101
330
Hello all, I am looking to buy this AIO CPU Cooler by Enermax:
https://www.newegg.com/Product/Product.aspx?Item=N82E16835214096&ignorebbr=1
I have this Super Tower PC Case by Thermaltake:
https://www.newegg.com/Product/Prod...=thermaltake_tower_900-_-11-133-327-_-Product
Any pre-built AIO CPU coolers by popular brands like Corsair/Cooler Master/Etc. cannot be installed on the back because there is no room to push the Waterblock from the back to the front. You can only install a custom water/liquid radiator in the back of this case. Thus, the only place to put the AIO I want to buy by Enermax is in the front of my PC case.
However, according to the PC case specs, it says: "Top: 2 x 120 / 140mm (2 x 140mm Turbo fan (1000rpm, 16dBA) included)". Does this mean that the Enermax AIO is too big to fit the front-top of the PC case? Because its 360mm?...
If you scroll down on the case page on newegg website in the Overview tab it says it supports AIO radiators on both left and right sides and there's a schematic. The orientation in the schematic is staning and no it can not fit the top front. That part you quoted if for top fans and it says they're included.
To be 100% certain I think it's best to ask Thermaltake support.
