[SOLVED] Im not sure if i choose a right PSU for MB
Is your choice right? The wattage is enough, decent cables and it will work with your config. However, you can get better options in this price range. The only downside is that this brand is not respectable. 90+ certification is great but you should go for something from evga, corsair or seasonic.
Remember when choosing your PSU, it must be 600w for future upgrades and statbility. Also keep in mind that it has atleast 80+ bronze certification. The most important thing is to stick with the top manufacturers and their popular series.
Here are a few recommendations for your system:
EVGA SuperNova 650:- https://pcpartpicker.com/product/y8...ed-fully-modular-atx-power-supply-220-g3-0650...
I would definitely get a beefier power supply. The video card works with most anything, and although it doesn't take a lot of power it is still a higher end graphics card and so it has significant power requirements. No opinion on the motherboard, but if you don't say how you plan to use it and how much ram there isn't much to say.
Corsair RM650x:- https://pcpartpicker.com/product/2H...-fully-modular-atx-power-supply-cp-9020178-na
EVGA-110-BQ-600w:- https://pcpartpicker.com/product/Dm...-semi-modular-atx-power-supply-110-bq-0600-k1
SeaSonic Focus-Plus 550w Gold:- https://pcpartpicker.com/product/bk...fied-fully-modular-atx-power-supply-ssr-550fx
Cooler-Master Masterwatt 550w:- https://pcpartpicker.com/product/B6...mi-modular-atx-power-supply-mpx-5501-amaab-us
