Improve Speed
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
OS Win. XP Pr😵ffice 2003
If a programme (Spam Interceptor) is slowing down to open on a right click
on the desktop shortcut icon, what could be the reason (others produce
immediate positive response) and how can one eradicate this problem? Thank
you.
Give some details about your computer.
Colin Barnhorst [MVP Windows - Virtual Machine]
(Reply to the group only unless otherwise requested)
"annonymous@discussions.microsoft.com" <annonymous@fsnet.cvo.uk> wrote in
message news:OU5resMFFHA.464@TK2MSFTNGP09.phx.gbl...
> you.
Remove the program. If you need spam control tools, they should not
slow down your system. Try f. e. the MailWasher
(http://www.mailwasher.net), which does not have such side-effects.
(tm)
It is the MailWasherPro I am complaing about!
"Thorsten Matzner" <tmatzner@gmx.net> wrote in message
news:eMZ2JSQFFHA.3908@TK2MSFTNGP12.phx.gbl...
> (tm)
Hi Colin,
The information you requested is as follows:
PC by Fujitsu Siemens
Processor Pentium 4 - 3.20GHz
120 GB Hard Drive (over 80% free)
512 MB DDR Ram
GA-81PE 1000 Series Mother Board.
If you want any further information, please ask.
"Colin Barnhorst" <colinbarharst(nojunk)@msn.com> wrote in message
news:eI%23vRtRFFHA.2700@TK2MSFTNGP14.phx.gbl...
>> click on the desktop shortcut icon, what could be the reason (others
>> produce immediate positive response) and how can one eradicate this
>> problem? Thank you.
Do you have a second hard drive? I assume not since you don't list one. I
improved my virtual machine performance by putting the virtual machines on a
second drive. I use a second SATA internally and a usb2 external and have
used both for my virtual machine files with good success. Given your
hardware, I am surprised that anything slows the vm. Have you tried opening
the task manager inside the vm and watching the processor load while right
clicking the desktop icon?
message news:O42o94YFFHA.3924@TK2MSFTNGP09.phx.gbl...
> Hi Colin,
> 512 MB DDR Ram
>>> problem? Thank you.
Then I would contact the support for the application. As I wrote,
Mailwasher runs well here, so there may be a problem with your
installation.
(tm)
Many thanks for the suggestion. I will try a second hard drive, since I have
been thinking about installing one. I will also try the other suggestion.
Thanks again.
news:OdDIcHZFFHA.732@TK2MSFTNGP12.phx.gbl...
> I improved my virtual machine performance by putting the virtual machines
> on a second drive. I use a second SATA internally and a usb2 external and
> have used both for my virtual machine files with good success. Given your
> opening the task manager inside the vm and watching the processor load
> while right clicking the desktop icon?
>> Hi Colin,
>> 512 MB DDR Ram
>>> in message news:OU5resMFFHA.464@TK2MSFTNGP09.phx.gbl...
>>>> problem? Thank you.
