I've been having a lot of trouble trying to install my gpu.
I run i3 2120 with a 430W corsair and h61 mobo.
When i connect/plug the gpu in and turn on the pc, the fan on the gpu runs fine and that indicates that all is hooked up correctly, i assume.
Anyways, when i insert the disc for driver installation on the zotac gtx460, it lets me choose my OS, etc. Then it'll come up with a message "The NVIDIA Setup program could not locate any drivers that are compatible with your current hardware. Setup will now exit."
I also tried installing the driver from the NVIDIA website and when I try that, it states that it doesnt work with my hardware.
I do have integrated graphics and i've already tried disabling and installing the gpu afterwards. No go..
Anything else I can try?? I'm on windows 7, 64 bit if that helps.
edit: also, when i go to my device manager, there is no sign of the gpu at all..
