Question Installed new PSU, some case fans controlled by a fan controller/hub are not working properly
Dec 11, 2021
4
Hello!
I am new on these forums so do excuse any bad formatting. If the post is in the wrong section, pleas do move it.
So long story short. I got my hands on a 3080 ti and wanted to have more overhead so I also upgraded my PSU from an EVGA G2 750 Watt 80+gold to a Seasonic PRIME PX 1000 Watt 80+platinum.
I had no trouble with changing the PSU. I am using the new cables as one should use and everything works fine besides four of my seven fans.
My back fan is connected directly into the mobo and so are two of my right side fans. But the rest were controlled via a fan hub/controller that is integrated into my case, a Cooler Master Storm Trooper. I had no problems with my old PSU.
So I don't know what to do. I used the same setup with cables. Connected the 3-pin molex into a 4-pin molex then directly into the PSU to give power to the fan controller/hub yet those four fans are not spinning.
My pc specs below with pics of the not spinning fans and the 3-pin into 4-pin molex in the back of my pc.
View: https://imgur.com/a/ilDeZs7
AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor
Noctua NH-D15 82.5 CFM CPU Cooler
Asus ROG Strix X570-E Gaming
G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL14
Samsung 870 Evo 500 GB 2.5"
Samsung 980 Pro 1 TB M.2-2280 NVME
Gigabyte GeForce RTX 3080 Ti 12 GB GAMING OC
Seasonic PRIME PX-1000 Watt
Noctua A14 industrialPPC-3000 PWM 158.5 CFM 140 mm Fan
Noctua F12 industrialPPC-2000 IP67 PWM 71.69 CFM 120 mm Fan x6
TommyTwoTone66
BANNED
Apr 24, 2021
983
187
640
118
I would swap back to the old PSU and return the 1000W Seasonic.
750W was already way more than you needed for a 3080Ti, so you do not benefit from moving to a 1000W PSU.
Seasonic are not an amazing brand and as you are finding sometimes higher wattage PSUs don’t quite behave as expected with low power devices like fan controllers.
Alternatively, remove the fan controller entirely and connect all fans to the motherboard. 3-way fan splitter cables are pretty cheap and easy to get.
Dec 11, 2021
4
Ye that is my solution to this problem. I wanted more overhead because I want to future proof. My total wattage puts me at 620ish watt so I have ca. 130 watt overhead. But the 3080ti is power hungry.
I will try solving this else I will just buy one 5-way splitter and problem solved I guess. I just really want to know why it is not working. I am using 100% the same type of cables and connectors. Thank you for the input though.
TommyTwoTone66
BANNED
Apr 24, 2021
983
187
640
118
Sometimes the answer to why is not available to us.
At a very basic level, your new PSU is not sending power correctly down it’s 4-pin molex connector.
For more detail than that you will need to do electrical testing on the PSU.
“Future proofing” is a huge waste of money and time. You don’t know the future. Maybe the 3080Ti is the most power-hungry GPU you will ever buy.
Dec 11, 2021
4
I found another "solution" or something I will try. Going to the store to buy a 4-pin molex to SATA connector which might fix this. Else I will just order a 5-way y-splitter and use that instead of the hub/controller.
