Question Intel i9 14th gen cpu temps under a Dark Rock Pro 5 Fan
Jul 9, 2024
Hey!!! I recently built my first gaming PC and after playing cyberpunk for an hour I went to check my CPU temps. It was at 82 degrees Celsius, and I noticed that on idle at the home screen with only discord on my CPU temps have been anywhere between 55 to 60 degrees. Does this call for any concern? I would love to hear others' opinions on this theard for suggestions and hopefully some peace of mind lol.
...under a Dark Rock Pro 5 Fan...
only using the fan from a Dark Rock Pro 5 set?
why not the whole cooler?
if you have actually installed the be quiet! air cooler and are still seeing these temps it's likely you did not install it correctly.
and/or have not properly setup the fan speed profile for this type of use.
Reactions: LuckyBrandon069
I am using the entire air cooler with both fans installed my bad for the confusion. I probably did install it wrong as it was the hardest thing to install throughout the entire process. However I forgot to mention that I don't have an exhaust fan installed on the back of computer and it was hot in my room while playing.
Latest posts
