Question Is asrock z77 extreme 4 compatibility with rx 570?
May 4, 2019
Hi everyone,
i have to buy a new graphic card (i don't have one) and i saw the msi radeon rx 570 8gb but i don't know if it is compatible.
The msi official website said pci x16 but on the other shops online everybody said pci x16 3.0.
Than you if you can help me!
It will fit no worries if the motherboard has a PCI 16x slot. To help you understand, the number 1, 2, 3 (in your case 3.0) stand for the version of the PCIE slot and x4, x8 and x16 is the size of the slot. If your motherboard has a 16x slot your RX570 will fit. If it has a x4 or x8 slot it will not fit.
With that specific motherboard it will fit as your motherboard has 2 3.0 16x PCIE slots.
Hope this helps.
