I was testing a bunch of different fan orientations and this one in particular did the best in terms of cooling.
From the regular Neutral Airflow to this for comparison
35c to 29c idle and 57c to 51c load on the CPU.
40c to 38c idle and 65c load on both with the GPU.
Is it worth the cooling or is there problems with this?
Should I probably move any fans somewhere else?
I do care about dust but I do like seeing very low temps and everything performing at it's absolute best
This is the Neutral Airflow I compared to:
This is something else I tried, 32c idle 55 load CPU and same results on GPU:
