Question issue with wifi being not available sometimes
Dec 13, 2024
41
so i got this gigabyte b650 arous elite and i been having this issue where the WIFI shows that it is not available at all and when i boot it on it shows it is available but after a while it becomes not available . i am using lan rn but i still need to use the wifi and all so what can i do? or do you think it a motherboard issue i am not sure on how to upload the images but the wifi icon is blue and when i click on it shows no network but it is on
what i have done
i changed the anteena
i made sure to install the drivers
i relocated the anteena
What OS & version?
Have you tried downloding the wifi driver package if available from the manufacturer website and install as Administrator?
Failing that, you could reset your network from within windows and reboot to try.
What OS & version?
when i tried on the website it bsod my pc
IRQL_NOT_LESS_OR_EQUAL and ryst64x64 error
i using windows 11​
If you cant boot normally into windows, boot into safe mode and uninstall the wifi driver in device manager & reboot. Unusual to bsod from manufacturer.
Or, you can right-click on the wifi adapter go to the Driver tab and click RollBack Driver.
Hi so I tried on admin so after so time just restarted my pc idk if jt bsod there wasn't any blue screen just a restart is that correct?
If its an .inf file you can right-click on it and click install. Would pay to look at the manufacturer driver date and the current one or rolled back driver.
If you need to reset the network to try then go to...
Settings > Network & Internet > Advanced network Settings > then click on "Network Reset" on that page. That will change all network settings to the default.
