G
Guest
Guest
So I have about 3,500 songs on my Itunes and it says its taking up 22.5GB of space... From what I know my Ipod Touch 32GB should hold about 7,000 songs. So the math doesn't add up... Plz help! is there a setting that I might need to change that brings the GB of space down? cause b4 I bought my new (WD 1TB 7200rpm 32mb cache) Harddrive I had the exact same amount of songs but it said it only took up 13GB.
