Hi
I want to add PE foam beneath my PCB and next to the body. I've found this in my graphic card box but I don't know if it's anti-static.
Also, I want to use this PE foam on the PCB under the switches, but I'm not sure it's anti-static like the other foam. I came with my monitor it was in this foam.
Also, I'm going to lube my stock stabilizers (205g0) and use a typical dielectric grease for the stabilizer wire in those plastic parts.
I'm not sure if it's necessary to use masking tape for the back of the PCB. Should I do that?
I'm mostly concerned about the anti-static problem with the PE foam.
