Question Kernel-Power 41 (63)
Apr 18, 2022
I did everything, I don't have oc, I sent to check my graphics and they said it was fine, I changed the processor, I replaced the motherboard, I updated the bios to the latest version, I checked the ram with memtest without errors, I checked cpy and gpu temperatures with Aida and prime95 tests without errors. I reinstalled windows 10 but only with my personal settings and it keeps giving me kernel error 41, I don't know what else to do. Of course the only thing that activates the bios is the automatic xmp ram. I checked by removing it and it keeps giving me errors and it is also not an option because my pc becomes a turtle.
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2022-04-18T20:55:18.3744296Z" />
<EventRecordID>19461</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-A5J6HQ5</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
<Provider Name="nvlddmkm" />
<EventID Qualifiers="49322">14</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2022-04-18T20:55:25.0312947Z" />
<EventRecordID>19488</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="260" />
<Security />
</System>
- <EventData>
<Data>\Device\Video3</Data>
<Data>CMDre 00000000 00000200 00000000 00000005 00100042</Data>
<Binary>0000000002003000000000000E00AAC0000000000000000000000000000000000000000000000000</Binary>
</EventData>
</Event>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2022-04-18T20:55:23.0000348Z" />
<EventRecordID>19484</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="548" />
<Security />
</System>
- <EventData>
<Data>CMDre 00000000 00000200 00000000 00000005 00000042</Data>
</EventData>
</Event>
For the love of God what's going on? I even ran all over google tried to see a solution. Nothing fixes it for me. I put my RAM in "Power Down Enabled/mode" to disable and "Gear Down Mode" enabled. But I keep getting the error. This last one of the thousands of solutions that I saw on the internet and nothing. Then I put it back as it was just in case but I still get all these errors. I don't understand anything. It also happens to me when I do absolutely nothing on the PC, I don't even touch it, I just leave it on and it restarts. The same thing happens when I'm in the bios without doing anything, another reboot because with these events. This is really frustrating, so much so that if I found a solution I would spread it so that the same thing doesn't happen to someone else. I have had this error for months.
By the way, I also changed the power supply from a nox urano 650w 80plus bronze to a corsair 750w 80plus bronze, but the error continues. Equipment: AMD RYZEN 7 300X, RTX 2060 WINDFORCE OC 6GB GPU, Corsair H100x Hydro Series Liquid Cooler, Corsair Void Elite RGB Wireless, Mars Gaming MCZ, Gigabyte Technology B550M DS3H Sockel AM4 Motherboard, Samsung 970 Evo Plus, M Solid State Drive .2 1000GB NVMe, PCI Express 3.0, Corsair CMK16GX4M2B3200C16 Vengeance LPX 16GB (2 x 8GB) DDR4 3200MHz C16 XMP 2.0, BenQ GL2580H, BenQ MOBIUZ EX2510
I am getting the same error as you. Only seems to crash and restart when applying light load on the system i.e. browsing the web on any browser or doing literally nothing on idle. No restarts on cinebench or prime95 24hours stress test. Gaming works fine until I exit the game and boom! It crashes.
Reactions: klok25
Estoy recibiendo el mismo error que usted. Solo parece bloquearse y reiniciarse cuando se aplica una carga ligera en el sistema, es decir, navegar por la web en cualquier navegador o literalmente no hacer nada en inactivo. Sin reinicios en cinebench o prime95 prueba de esfuerzo de 24 horas. El juego funciona bien hasta que salgo del juego y ¡bum! Se bloquea.
[/CITA]
Ya I already found out what my mistake was and that is that the processor was defective, sir please apply the warranty and have the processor changed. I did the same thing and put the new processor and it no longer gives me that error or others that I had there. Pay attention and you will see how it is solved and if it does not work for you that I doubt it very much, try to change the power supply and that's it. I hope and it serves you :)
Reactions: theboeingman
I replaced my 12900K with another 12900KS. The problem is gone. No more Event 41 Kernel error and no more stability problems with RAM. The defective CPU was causing memory instability and random black screens and subsequent reboots/bootloops. All this time i thought I had bad ram sticks or faulty motherboards and GPUs. For anyone else with such issues, I recommend you email Intel and demand an RMA replacement. They sent a 12900KS out to me for free. The process takes around 1 month to email back and forth.
