Keyboard keys function wrong. EG. Shift/2 = " [not=@]
peter1
Please can help, some of my keyboard keys are not correct.
Do you know what is problem.
when I press Shift/2 (") is typed, it should be (@)
when I press Shift/3 (£) is typed, it should be (#)
3 more keys are wrong too.
Peter1
chookman
3,319
Check regional settings in control panel most everything should be set to Australia, on the languages tab click details and make sure the keyboard is the correct one.
chazy
here's how...
1. go to control panel and open "clock,language and region"
2. there'll be a pop-up then choose "keyboard ad languages" tab
3. then choose a default language as
English (USA) instead of some other formats...
if it has more than 1 format, remove other formats
Done...
ajguimba
THank you for your good ideas....
anjo
Kas Rangel
Hey,
Thanks, it was very helpful. just to add - I had to reboot my PC for it to apply the changes...
shihabudeen
Chams Chamling
thanx thanx thanx dear
AJITH WASANTHA
