G
Guest
Guest
I don't really know where to begin, but here it goes:
Instead of boring you guys with a story of how i hate koolance now, im gonna give you little headers of what i did to the case to try to make it work:
This is the problem: Comp boots for only 2 seconds, and then somekind of failsafe mechanism shuts it down.
-checked every connection, everything's fine
-tried different power supplies
-tried both KT7-RAID and K7S5A motherboards
-tried resetting BIOS on both
-took out everything on the motherboard except cpu, still nothing
-tried using the fan i used on the other comp, and plugging the fan into the motherboard, leaving the cpu waterblock hanging in the air, still shuts down
-(the water system works when jumping the ATX, so that is fine) It's when i connect it to the motherboard and try to hook everything up, it shuts down
-tried every kind of switching possible to me..
Here is what is interesting: When i take out the cpu, then it doesn't shut down the power... so it has to do with the motherboard thinking that the cpu is being overheated.
Another thing: i hear a clicking noise when the power is shut down not on the motherboard, but on the Power Control Board...is there a jumper i have to set???
-manual is a piece of [-peep-], i had to figure most of the stuff out <---- little sidenote
As you can see, I am at the verge of becoming insane, I have been up for almost a day and a half now, and I am out of options: Any help would be appreciated...
