The heating issue cropped up about a month ago.
Plugged in temp: 65-75C, Frequently hitting 98C but not continuous while using chrome.
Battery temp: 40-50C, Temperature remains lower than 50 while using chrome.
I use Adobe Auditions, Solidworks and play Minecraft, but the temperatures remain almost the same as in plugged in chrome, a little higher.
But while on battery, the laptop still runs a little cooler (not checked, just felt the warmth) in all these applications as compared to when plugged in.
The laptop was bought in Sept 2019, specifications are:
i7-9750H
Nvidia 1660 Ti Max Q
512GB SSD
1TB HDD
12 GB RAM
(HP Pavilion gaming 15)
No high CPU or GPU usage is observed on charging or battery. I found a post https://answers.microsoft.com/en-us...-fine-on/f8d94317-bd4a-4267-9af8-cf6dc3251554 and followed it.
Since the problem is major with chrome, I assumed that it could be due to hardware acceleration and so closed it from chrome but that had no effect
In the Nvidia control panel, I chose Intel instead of autoselect. But still no change.
In HWMonitor I observed that there is a change in Power Limit, Temperature Limit, and Utilization Limit for the GPU when I unplug the charger. What should I do next? Could someone please explain what exactly is happening.
i7-9750H
512GB SSD
1TB HDD
12 GB RAM
