Question Lian-Li O11 Dynamic XL fan setup?
Flame1
206
6
18,615
So Im picking up the case tomorrow along with the Lian-Li PC-O11DXL-1 Riser Cable and I don't know how I should mount my fans. I have 7 Corsair LL120mm fans, 280MM AIO and I will be vertical mounting my GPU. I was thinking to maunt the AIO on the top as exhaust, bottom fans as intake, back fan as exhaust and the side fans as exhaust. I wanted to keep the side fans as exhaust due to the fact that those LLs look much better from the front. Some people told me that I could make this work by adjusting the fan curves properly but I want to see what others think.
Here is a link for a sketch i made of how I was thinking to set up the fans: View: https://imgur.com/koUh36Y
Thanks in advance.
Thanks in advance.
For all those fans, you need to either make sure your mobo has enough fan headers, or you will need to use a fan controller
