[SOLVED] Lian Li PC-011 Dynamic EVO compatibility and worth it?
thewalleprod
165
Currently have a NZXT H500 with an i7 8700k and 3070 ti, temps are in the higher range and was thinking of buying a new case with better airflow that can seat more fans. I came across the Lian Li Dynamic and was wondering if this case is compatible with an Asus Prime Z370-A ATX board? Also, would the switch over from case to case give me any trouble where I could ruin the hardware? I currently have a 240mm AIO cooling the 8700k which I would also install in the Lian Li.
Thanks
