Ok I am a total n00b in LC. So I was thinking about getting the Thermaltake Kandalf LCS Case that has a pump, radiator, tubing, coolant, and a CPU block. Is it a good value? How about the armor LCS? So what would be better me buying a case then water cooling it, or going and getting the set. I would not like to spend over $300 on the case+ LCS. If putting together my set is a better deal, can you recommend some stuff.
My future specs
Case= You tell me
CPU= Q6600
HDD= Raptor 150gb
Graphics Card= EVGA 8800 GTX
PSU= OCZ gamextreme 700W, or anyone elses recommendation
MOBO= Abit IP35 Pro
Moniter= 22 inch SAMSUNG 226bw, I think...
RAM= 4x1gb crucial ballistix DDR2 800 4-4-4-12 (Maybe tracers)
DVD drive= Some cheap drive (I dont really care as long as it is SATA and quiet
Thank you for reading my life story and thank you for posting
My future specs
Case= You tell me
CPU= Q6600
HDD= Raptor 150gb
MOBO= Abit IP35 Pro
