My capture card starting crashing and having some pretty bad issues, I originally attributed these issues to the fact some files probably got messed with after I had a malware probably, which prompted me to do a complete system wipe.
However while the device no longer crashes the device seems like its buffering whenever I look at the record and preview window its jumps and skips. Using the newest software as well as firmware on this system
Here is a video : https://drive.google.com/file/d/1i0f-VqchsGl2RdykU-rx62SE67-Hrh6lVQ/view
Now tech support wants me to just replace the device but having tried the same device on my laptop the device seems like it works fine.
As per request of a friend I went and installed a USB 2.0 Card on my PC to see if maybe it was the USB ports on my system the problem still persists.
So that leaves me with three option, either some is borked on my PC even after a fresh install, ALL the USB ports are bad, or the device itself is bad.
My System: 8320 FX, 16 gigs of GSkill Ram, GTX 970
