G
Guest
Guest
Archived from groups: alt.games.microsoft.flight-sim (More info?)
Hey Everyone,
I've been having an issue with a Logitech Extreme 3D Pro joystick for a
while now. I've recently confirmed the problem on my gliding simulators. I
had to replace my mother board a few weeks back so I haven't re-installed
FS2004 and all my add-ons yet. When I plug the joystick in the calibration
is fine and has full movement. A few minutes into the sim movement to the
right and right rudder becomes limited and hardly moves. I've done a web
search and this appears to be a common thing with Logitech controllers. I've
tried uninstalling the Logitech software which allows manual calibration.
After a few minutes into the sim the same thing happens reduced movement to
the right. Pushing left gives full movement. The only cure I've found is to
keep unplugging/re-inserting the usb to reset it.
I was wondering if anyone knows of a fix that works. OR can recommend a
replacement joystick that they've found to be reliable. I've had the Extreme
about 2 years now. The only thing is I'm left handed so I'd be looking for a
stick/buttons that are comfortable with either hand.
Any thoughts would be great.
Cheers,
Rick
Hey Everyone,
Cheers,
Rick
