I'm fairly limited in my knowledge regarding the BIOS configurations, hardware, and the relationship between how internal and dedicated graphics cards are utilized and really appreciate any knowledge / further explanation of what's important or what is going over my head.
I recently upgraded to a desktop pc and use Adobe programs (mainly Photoshop, Illustrator, and InDesign) and was hoping to get advice on the best settings / configuration for performance when using multiple programs at once or doing graphic-intensive projects.
My Specs:
Motherboard: MSI PRO X670-P WIFI (MS-7D67)
CPU: AMD Ryzen 9 7900X
Internal GPU: AMD Raphael - Internal GPU [MSI]
Dedicated GPU: AMD Radeon RX 7900 GRE
Memory: T-Force 2x32 DDR5-6000 SDRAM
OS: Windows 11 Home x64
BIOS Settings that I have configured myself:
Overclocking > DRAM Settings;
A-XMP: Enabled
Settings > Advanced > Integrated Graphics Configuration:
Initiate Graphics Adapter: PEG
Integrated Graphics: Game Mode
UMA Frame Buffer Size: Auto
HybridGraphics: Disabled
What I'm hoping my current BIOS settings are achieving:
- Able to plug in the HDMI to the motherboard and utilize both graphics cards
- Optimize the memory cards for performance (by turning on the X-AMP)
- Expand the DRAM so that I can enable the GPU performance settings in the Adobe programs
For clarity, I am not comfortable changing any overclock settings (don't have enough knowledge to trust configuring myself), and instead am just looking to make sure I have an optimized base setup and that I am not doing anything redundant / unnecessary if that makes sense.
Thank you so much in advance for any tips or insights you have!
My Specs:
A-XMP: Enabled
