Looking for cooling advice
mikebjr86
8
I have been noticing hotter temperatures on my CPU after I installed a new GPU in my system and I am trying to identify the problem. Here is my setup...
Case: Rosewill Challenger
CPU: AMD Phenom II x4 955 BE
GPU: HIS Radeon HD 6950 2GB
Other than this, I have a bottom mounted modular psu, 1 HDD, 1 optical drive, and 2 sticks of 2 gb RAM.
Currently my CPU is idling around 35C and will get as hot as 61C while playing games. This has me concerned because I believe the max temperature for my CPU is around 62C. With my previous GPU installed, I was getting cpu temps that were around 30C idle and mid 50s when gaming, and it was a much smaller card.
I am wondering if this is an airflow issue, since the HD 6950 fits pretty snug in my Rosewill Challenger case. My case came with 3 fans already installed, and there is space on the side of the case for 2 more 120mm fans. Would installing fans on the side cool my CPU down a bit better? If so, should they be intake fans or exhaust fans? If it's not a fan issue, should I replace the thermal compound on the CPU? Or maybe buy an aftermarket cooler for the CPU?
I should mention that everything on my system is running at stock settings, nothing is overclocked. The cooler on my CPU is the stock cooler as well.
Thanks in advance for any advice or suggestions.
I'm thinking there is more to it than that... stock speed CPU's should not need an aftermarket cooling solution and slapping one in will not address the problems. Try running you computer with the side panel removed, see if your temps go down that way - if so, then a side panel intake fan will help. If your temps don't change include that info.
Yep love the Challenger (currently housing my i5) and you can mount a fan (or two) on the side panel right over the GPU's - I found I ran cooler that way plus it looked really cool with two blue fans there.
Here is an update on my situation:
I tried running my system with the side cover off as Friedman suggested, but was still getting the same kind of idle temps that I was getting with the cover on. I just don't think that air is getting circulated to the CPU well enough. My cable management could probably be a lot better as well.
Anyway, I went out and picked up the cooler that hellfire suggested and installed it last night. Right away my idle temps dropped down to around 30C. I booted up Battlefield 3 and played a couple rounds to see how well it was handling under some stress. The CPU did not get over 50C after playing a few rounds. I think I was hovering around 47C or 48C where before I was getting as high as 61C. Needless to say, I am pretty happy with how well the Hyper 212 Evo is cooling the CPU now.
There may have been a cheaper solution to my problem, but I figured I would just pick up the after market cooler since I plan on overclocking at some point anyway (I am fairly new at system building and haven't really learned how to overclock just yet).
Thanks for all the help and suggestions!
^i hope you are done and if you are then please mark the thread as 'solved'.
any way here are a couple of suggestions-
1-improve your cable management if you can,here's some help-
http://www.overclock.net/t/1143934/rosewill-challenger-cable-management
2-add a high cfm fan such as slipstream on side to blow air on your cpu and gpu.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185060
now your airflow will improve and temps will drop.top and rear fan will take care of sucking out the hot air.
The 212 +/EVO are the two best HSFs under $60 by a fairly wide margin. They may not be the absolute cheapest solution but not by much (only $5-10 more expensive than the cheapest aftermarket HSFs on the market) and well worth it for all the extra performance it brings.
Graph or table, it makes no difference. Keep in mind that the graph shows the ambient-to-core temperature difference and you get the exact same values from the table.
If your room temperature is 5C hotter (as is the case in that table/graph between the 212 and 612), your core temperatures will necessarily be around 5C hotter as well since heat movement is primarily dictated by temperature differentials.
