[SOLVED] Low FPS in Minecraft with shaders?
Aug 31, 2020
Well, I have a PC with these specs:
a320m asrock hdv-4.03
Ryzen 5 2600,
RX 5600 XT,
16 gb ram dual channel 3200mhz,
240gb ssd,
1tb hdd, .
My problem is that whenever I use a shader in Minecraft, the fps go below 60 and stays around 20-45, it doesn't matter if I'm using a texture pack or not it's only when I'm using shaders, but, when I turn off the shaders the fps go to 200-300 even with the same texture pack. I'm adding pics for you all to see.
I'm using AMD RADEON 20.4.2 drivers because with the latest drivers (20.8.3) the game doesn't even starts with shaders, I even assigned 10GB ram to the game to see if it was the problem and nothing changed, I'm desperate and hoping you all can help me.
Sorry for my english, thank you all so much. I must say that in some images the fps counter shows 60 fps or above it, well, don't look it that much because the game almost everywhere stays around 20-45. Oh, and one more thing, I can run any other game at ultra 60 fps or above, even Horizon Zero Dawn and it won't even lag.
Make and model of your PSU and it's age? I'm a little confused, are you on the R4.0 version of the motherboard or are you on BIOS version 4.03? Regardless, see which BIOS version you're on currently and see if you have any BIOS updates pending.
Hi! You will probably don't know my PSU because it's from national fabrication, but it's name is "Sentey DP650-FX 650W Solid Power 80 Plus White" (I'm adding a link for you to see more details of it, It's in spanish but there aren't any sites of this PSU in english). I bought my entire pc 1 month ago, all the components are factory new, I updated my GPU bios to the latest (my gpu exact model is "Radeon RX 5600 XT Phantom Gaming D3 6G OC" and I have installed the D12 Bios that's on the official page.) My motherboard is "Asrock a320m-hdv R4.03" (idk why but even in the official asrock page there aren't any models named R4.03, but in the box that I have it says R4.03 lol, I think that the difference between R4.0 and R4.03 it's that the R4.03 has more USB 3.0.)
Last thing, i don't know my BIOS version right now, but I'll check it in a few minutes.
Thank you so much for your answer! ^^
https://compragamer.com/producto/mother_asrock_a320m_hdv_r4_03_ryzen_m_atx_6165?redir=1&nro_max=50
https://compragamer.com/producto/fu...w_solid_power_80_plus_9116?redir=1&nro_max=50
