Question Low fps on a lot of games at 4k with RTX 4090
BarakYisrael
16
my specs are 32gb rams oc speed at around 4000mhz, cpu i9-9980xe with like 6 of the cores oc at about 4.8 4.9 ghz, mobo is ROG RAMPAGE VI EXTREME OMEGA. i noticed when gaming at 3840 x 2160, 7680 x 2160 etc i get frames not above 70 average. shouldnt i be getting higher fps with rtx 4090 even with bottlenecks? i mean how much am i really bottlenecking. can you guys help me figure out?
Depends on the game and settings.
Turn your settings to all low and see if the FPS goes up if so nothing to fix.
Core I9-10980XE
It will perform better than what you have, but not by huge margins.
To raise the performance bar, you'll need to change the CPU, motherboard, and memory to get to modern levels of performance.
Yea i was checking on cpubenchmark it doesnt really seem like it improves by much at all. Like 5percent increase in some areas. Guess i just gotta get whole new system.
