Question M.2 screw hole has no binding
Jul 6, 2024
18
hello i’m trying to install a m.2 into a Asus Prime B450M-K i don’t have any standoffs or screws and i’m not sure what ones i would need and i don’t have anything that came with the motherboard, it’s just a little hole with no way a screw can be fitted
quite confused as this is my first time building also
hello i’m trying to install a m.2 into a Asus Prime B450M-K but in the screw hole there’s nothing, no binding, nothing for the screw to tie into just a empty hole and i’m not sure how to screw it down if the screw hole has no binding
Please stick to one thread
This is what you'll need to fasten/secure an M.2 drive on that board;
View: https://youtu.be/Vo_Un6StrtQ?t=186
The thing labelled as the M.2 anchor;
https://dlcdnets.asus.com/pub/ASUS/..._PRIME_B450M-K_UM_WEB.pdf?model=PRIME B450M-K
page: 1-10~1-11.
Or instead of asking us, you could just contact the shop you bought it from and get them to order one in for you.
this isn’t a possible scenario
Why not? There’s also a pile of them available from eBay.
this pc was built by my family (not me) and they wouldn’t have the answer for this, i’ll happily buy anything i need from ebay to get it to work but i bought a “m.2 screw kit” but as the hole has no binding how can any screw kit work with no binding?
That motherboard came with a mechanism designed for it. That would be the preferred option.
I suppose one could fabricate a mount with some spare parts. You need a standoff of the approximate height of the original mount, but with a screw shaft long enough to extend through the motherboard to attach to a nut to hold in place.
