M-ATX: A7N8X-VM Pro/Cons
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi,
i'm considering using this MB for my living room multimedia machine. Any
pro/cons good/bad experiences ?
Thanks,
jorgen
In article <L4rtc.6475$XF2.2312@news.get2net.dk>, Jorgen [2400]
<popdreng_væk@popfyr.dk_> writes
Pros:
Simplicity (potentially)
Cons:
Memory fussy
Untweakable bios
Integrated video steals memory bandwidth
I had a nightmare with this card in an identical application and ended up
having to use a plugin agp card to get a working system.
If you're prepared to shell out on premium memory (and get a buyback
guarantee) then go ahead, but I would go for a non integrated asus (or
other) mobo with a cheapie nvidia TVout graphics card, mine's a GeForce4
MX 440 & it works well. TVout suffers from a bit of PC noise so not perfect
but I will prob sort that with a bit of filtering. nVidia control panel excellent
for full screen clone with loads of nice display options, far better than my
Matrox G450 which it replaces, but admittedly noisier.
HTH
fred
>Pros:
Yes, I was the easiest PC build I have ever done. Took me less than 2
hours to connect everything up and start installling the OS.
Once I had the drivers installed it ran like a dream.
>Cons:
>Memory fussy
I put a stick of 512Mb crucial 2700 memory in and its fine.
>Untweakable bios
I wouldnt expect anyone would want to use this board for tweaking.
Personally I have been quite impressed with the performance of this
Mobo.
I have had no issues with bandwidth whilst running various games and
software. Unless you are doing intensive work on this PC I doubt you
will have any issues.
The 8x AGP onboard is way better than a G450. I would say its even
better than a MX 440.
>HTH
I would buy this board again as its small and fast.
If you want a small form board then this is the one to get as it has
very good performance for a mATX board. If you want top of the range
performance then you'd be better off with a good quality ATX board.
HTH
Harry
In article <b91eb0hqshreetonmcdj8lqj95i5kliemm@4ax.com>, Harry
<A@A.A> writes
>>Pros:
>>Cons:
>>Memory fussy
Fine if that's what you've got (or gone out & bought), but don't expect it to
work with just any stuff you have just lying around.
>>Untweakable bios
>Mobo.
Not tweaking for performance, but for stability, no ability eg to put in a
some DDR400 stick you have lying around & run it 333 or 266, no choice
to run sync fsb/mem if you chose to etc.
It's only better if it's working, mem spec is waaay tighter when using
integrated video, but as you say you didn't have a problem with Crucial.
>>HTH
I think it's a good board too, with loads of good built ins, but I have my
reservations as a good number have had problems with memory.
Check out this thread:
http://www.abxzone.com/forums/showthread.php?s=d14d45fbfc26ad5abcc
675c4bbae45e1&threadid=67997
or have a look on google groups
>HTH
>Harry
fred
><A@A.A> writes
>>>Pros:
>>>Cons:
>>>Memory fussy
Fair enough, I have always bought Crucial or TwinMOS and have never
had a problem.
>>>Untweakable bios
>>Mobo.
This board has been very stable. As for adding DDR400, you may have a
point.
>>>HTH
Well, all I can say I have had a good experience with this board. I
guess as long as you buy reasonable RAM (Crucial, TwinMOS) then you
should have no issues. DDR400 or other brandds may cause issues.
cheers
Harry
>>HTH
>>Harry
