Hi
My girlfriends Macbook air (early 2015 Intel i5) won't charge. I delivered it to an licenced Apple Service Center in Norway, where they told me water damage was found.
They wanted around $1200 to fix it - apparently they had to change "The motherboard, the keyboard and one cable".
She says she can't remember doing anything particular - one morning the Macbook would not turn on.
After opening it I can't really find hard evidence on water damage - please see attached pictures. There are some miscoloration on the first pick in the far upper left color though.
So I was wondering - can you guys see any signs of water damage, and what can I do to start troubleshooting it?
All I've done after opening it is to visually inspect it and and detaching and attaching the cable to the battery.
Thanks so much for help - it's really appriciated!
Specs:
Specs:
- 13.3-inch (diagonal) LED-backlit glossy widescreen
- 128GB PCIe-based flash storage
- 1.6GHz dual-core Intel Core i5 (Turbo Boost up to 2.7GHz) with 3MB shared L3 cache
- 4GB or 8GB of 1600MHz LPDDR3 onboard memory (8GB maximum)
- Built-in 54‑watt‑hour lithium‑polymer battery
- 45W MagSafe 2 Power Adapter with cable management; MagSafe 2 power portt
- Intel HD Graphics 6000
