Question Man, I'm having a problem with my GPU? and Elden Ring.
Aug 20, 2024
So when I'm playing Elden Ring, every time a mob attacks me and the screen gets a little busy, my (GPU,Computer?) freezes for a split second, disconnecting my controller which resets. This leaves me just standing there for 2 or 3 seconds while the controller reconnects. I have tried every fix given to me by perplexity.ai and nothing works. I have also noticed that my browser freezes sometimes while on the internet, not sure if it's related. I read that it might be a conflict between my AMD and Nvidia? All my game settings are on medium, I'm playing windowed borderless. I also need to figure out how to change my Nvidia settings as an admin, even when I open as administrator it says I dont have permission to make changes.
Any one else have this problem?
Thanks
Graphics card is 8GB with multiple GPUs installed
I have an internal SSD with Elden Ring installed and an old external HDD connected.
Processor AMD Ryzen 7 6800H with Radeon Graphics 3.20 GHz
Installed RAM 24.0 GB (19.7 GB usable)
Device ID DEEE91E7-FF61-4E8F-A672-D8ACD7F9D5B0
Product ID 00342-20795-90454-AAOEM
System type 64-bit operating system, x64-based processor
Its an ASUS TUF gaming A15 about 2 years old in good condition. Bought new.
Event viewer-Application has the following warning sometimes:
DrvSetContext failed functionality indeterminant
(pid=25400 radeonsoftware.exe 64bit)
Event Viewer-System has the following warnings:
USB device draining system power when system is idle.
USB Device: VID: 0x45E PID: 0x2EA REV: 0x517
Removal action failed: SkippedAsPersistentIoObserved
File System Filter 'EasyAntiCheat_EOSSys' (Version 6.1, ‎2024‎-‎12‎-‎13T06:34:34.000000000Z) does not support bypass IO.
Supported features: 0x4.
The driver \Driver\WDC_SAM failed to load.
Device: USBSTOR\Other&Ven_WD&Prod_SES_Device&Rev_4008\575852314539393337355439&1
Status: 0xC000026C
Event Viewer-System has the following errors:
The GameInput Service service terminated unexpectedly
The GameInput Service service terminated unexpectedly. It has done this 5 time(s). The following corrective action will be taken in 1000 milliseconds: Restart
I have noticed just know that these errors are occurring while I'm in game.
Thanks!
What USB Device(s) are plugged in - that old external HDD via some USB connected case? If a case, does the case have its' own power source? (Versus relying on PC power via one of system USB ports.)
Other USB devices?
For the moment, try running "dism" and "sfc /scannow" to find and fix any buggy or corrupt Windows files that may be involved and contributing to the logged problems.
https://www.windowscentral.com/how-use-dism-command-line-utility-repair-windows-10-image
https://www.lifewire.com/how-to-use-sfc-scannow-to-repair-windows-system-files-2626161
Beyond that I will defer to the PC-Gaming Community in regards "EasyAntiCheat", "GameInputService", and "USBSTOR".
Status: 0xC000026C
Thanks!
I found this thread on the problem maybe being caused by having the XBox app installed on my PC. Just uninstalled it. Haven't tested it yet. What do you think?
Other USB devices?
I have my controller plugged into one port, and a splitter with 4 ports plugged into the other port. This one has my keyboard, mouse, and external HDD. It is not independently powered. My external HDD is full of errors in event viewer, its 15 years old and cannot be updated. It works fine though for all my games installed on it. (Elden ring is on internal SDD). I will follow your instructions (Thanks!) and see what happens. I will also try to disable the Easy Anti-cheat and see if that helps.
What PSU (make, model, wattage) is installed?
And look for an USB hub/splitter that has its' own power source.
Plus, if you have not already done so, be sure to back up all important data at least 2x to locations away from the host system and drive(s) in question. Verify that the backups are recoverable and readable.
Sorry, I didn't know how to find that info. I just ran a power report, but its a long long text. Do you want me to post it here or is there a better way?
Edit: is this it?
Edit 2: I never run the battery, I keep it plugged in at all times.
Installed batteries
Information about each currently installed battery
NAMEA32-K55
MANUFACTURERASUS
SERIAL NUMBER-
CHEMISTRYLiON
DESIGN CAPACITY55,997 mWh
FULL CHARGE CAPACITY47,204 mWh
CYCLE COUNT-
[TR]
[td]BATTERY 1[/td]
[/TR]
Desktop or laptop?
I was thinking desktop.
If desktop and you do not otherwise have the PSU information via the documentation then you will need to power down, unplug, and open the case to look.
Only do that if you are comfortable with doing so. Otherwise find a knowledgeable family member or friend to help.
Laptop: make and model? What power report did you run?
Reactions: Robrob76
Thank you for your help. You were right. The USB port would lose power for a split second whenever the GPU was overworked, then take a couple of seconds to recycle it's power and turn on again. I ended up just plugging the controller into a wall outlet and connecting it by to the PC by bluetooth. The issue has been resolved. I see now that a powered USB hub would also work, as you suggested. Thank you very much!
