hello.
i have been having a problem for quite some time\
my brother dose not use his pc any more and he allowed me to pillige it for components![Smile :) :)](/data/assets/smilies/smile.gif)
i emidiently thoght of his memory becuse i have only 8 gb of ram im my pc
my mother board supports 4 slots of memory so i thoght i could simply put in his memory as well
when i tired to put his memory in my pc and then tried to power it up, it beeped and didnt power on.
i have already tried to pull out this little battery on the mother board to no avail
i have 2X4gb sticks of ddr3 memory with a speed of 1600MHz
and he has 2X4 sticks of ddr3 memory with a speed of 1333MHz.
is it possible to combine to speeds and to brands' what am i doing wrong?
thanks in advanced/
my motherboard is a Gigabyte H97M-D3H
my cpu is a intel core i 7 4790
by brothers ram is a kingston 133dn9/2g 1.5v
i cant find the model of my current memory but this is waht cpu-z maneged to tell me:
DRAM frequency - 798.1
FSB:RAM - 1:6
CAS# latency (CL) - 11 clocks
RAS #to CAS# delay (tRCD) - 11 clocks
RAS# precharge (rRP) - 11 clocks
clcle time (tRAS) - 28 clocks
Row Refresh Cycle time (tRFC) - 208 clocks
command rate - 1T
edit no 1:
i have tired to change my bios settings to mach the 1333MHz clocks (all the other specs including voltage and timings are identical)
i shut down my pc and psu, installed the memory sticks but the pc still reacted the same (it did not boot and it beeped)
the model of the RAM i have installed is "F3-1600C9D-*GAB DDR3 CL9-9-9-24 1.5v)
thanks in advanced/
FSB:RAM - 1:6
command rate - 1T
edit no 1:
