Memory Upgrade with faster memory? will it work?
kamal
43
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
Hi I have a Dell Inspiron 510m Laptop with 2 x 256mb chips installed.
There are no free slots so i will need to remove one of the chips to
upgrade.
I have found the memory upgrade for this machine on the Crucial memory
website.
their recommemded upgrade is
1 GB DDR PC2700 · CL=2.5 · UNBUFFERED · NON-ECC · DDR333 ·
2.5V · 128Meg x 64 for £104.56
So i searched for this on Ebuyer.co.uk and found
Crucial 1GB DDR PC2700 333MHz 200pin SODIMM 128mx64 for notebooks
for £88.90 which I believe is the same spec.
However I also found
Crucial 1GB DDR PC3200 400MHz 200pin SODIMM for notebooks for £83.18
My Question is
1) can i use the faster memory than the specification.
2) Can i mix memory ie 1x256mb (PC2700) and 1x1gb (Pc3200)
thanks in advance for anyone who can advise
Kamal
Reply
On 10 Sep 2005 11:15:56 -0700, "Kamal" <kamalmehta@healthquest.co.uk>
>upgrade.
>website.
>My Question is
There should be no problem there. I haven't done exactly the same as you
but recently added a DDD333 SODIMM, from Crucial to a Thinkpad to go along
with the original DDR266 memory.
Yes again - should be OK.
Rgds, George Macdonald
Thanks George
Am ordering the faster & Cheaper PC3200 - will let you know if there is
a problem.
Kamal
