Question MIC PROBLEM ! ! !
Radijuska
Commendable
Apr 3, 2017
15
Hello i got this problem with headset (Hyperx Sting). When i plugin in to front panel, sound in headset is fine, but mic strange noise (look at attachment). After uninstalling and reinstalling drivers my headset becomes speaker and makes crisp sound in headset. but mic then works fine. I tried with driver booster to uninstal Sound, video and game controllers (Realtek(R) audio) After uninstalling sound disapears for 2sec. and again installs itself driver. But my headset is no longer working as speaker and crisp sound disapeared, but problem with mic came back.
Maybe i need to buy new windows?
Thank you.
View: https://imgur.com/a/teUgX3j
View: https://imgur.com/a/ZvGN2iS
(Better quallity)
https://voca.ro/bCFDKK10hsL (Sound)
Please don't use DriverBooster to modify, install or uninstall your drivers. If anything, source your drivers manually from product manufacturer's support site. If you're using the onboard audio then you're going to find the latest audio drivers on the motherboard's support site.
On a side note, make sure you're on the latest BIOS update for your motherboard and on the latest version for the OS(via updates).
