Micro atx vj and home theatre system
hardwork
11
Hello,
I'm trying to build a rig for doing live video performance and also to plug into my tv for home theater use. I most likely will be playing some games on it as well. I need it to be portable, so I think the micro atx is appropriate. I really would like to save a little money and have some good capability so am opting out of a lap top. The video work takes some juice and am hoping this can handle it. Any advice on overkill, underkill, anything wrong, incompatible, or just plain dumb? I would appreciate some input.
Thanks,
NZXT ROGUE Crafted Series BLACK ROGUE w. BLUE LED Black Aluminum MicroATX Mid Tower Computer Case - Retail
$89.99
Seagate Barracuda 7200.11 ST3750330AS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive
x2
$159.98
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
$229.99
OCZ GameXStream OCZ700GXSSLI 700W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply
$89.99
CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X4096-8500C5DF
$109.00
DFI LP JR P45-T2RS LGA 775 Intel P45 Micro ATX Intel Motherboard
$149.99
Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E850
$188.99
Subtotal: $1,017.93
Yup, DDR2 1066 RAM is pretty useless on an Intel build unless you're planning an extreme overclock. I'm assuming that's not the case because you don't have a cooler listed. Check this RAM out:
G.SKILL PI Black 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231209 $49.99
DDR2 800 RAM with 4-4-4-12 timings at 1.8v is about as good as it gets.
I'd avoid the 7200.11 drives. They're having major problems with them. For the same price, I'd pick up a couple of these instead:
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319 $79.99
hardwork
11
Great advice. I feel funny, I meant to list the dd2 800 but slipped up somewhere.
I most likely will not be overclocking. I know this form factor has a rep for bad cooling, and I am also not a skilled computer man. I like enthusiast specs without having the enthusiast know how. That is why I appreciate all the help from this wonderful forum.
Also, noted on the drives. Thanks.
I am going to put a new list up. Any other thoughts are very appreciated.
hardwork
11
Alright, new List.
I decided on a different graphics card based on reviews and crossfire ability vs. price point. All these folks are saying this is a crossfire only mobo, and there is no reason to get it unless you crossfire. There is this whole 8x or 16x dispute. i thought the mobo was great because it did not have onboard graphics, was p45, and geared for someone whole wants a small box and big power.
I do a lot of video performance so I need to be able to move this thing often. I was doing it with a full tower and a crt and it was a nightmare. I don't want a laptop because the power vs price is not to my liking. The DFI mobo seems like the only board up to the task.
One problem I have is that I need firewire. So many video devices, sound devices, and artsy type hardware is firewire only. I don't want to get caught with my pants down. I can get a pci card, but I bet the GPUs will cover the slot.
Thoughts?
$89.99
$188.99
$149.99
$229.99 x2
HP 20X DVD±R DVD Burner Black SATA Model DVD1060I - Retail
29.99
Rosewill 2+1 Port Firewire/1394a Low-Profile PCI Card (Cable Bundle) Model RC-501 - Retail
12.99
$89.99
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
159.99
Around $1000
hardwork
11
Yes!
This is it. i am going to get this stuff in the next couple of days. Any last thoughts? anyone? Is this is smart system? A little naive? Am I a fool?
Thermaltake VF1000BWS Black Aluminum Front Panel/ SECC Chassis MicroATX Desktop Computer Case
$129.99
XFX HD-485X-YDFC Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
$164.99
ENERMAX Liberty ELT620AWT 620W ATX12V SLI Certified CrossFire Ready Modular Active PFC Power Supply
$134.99
$12.99
G.SKILL PI Black 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-4GBPI-B
$74.99
$149.99
$188.99
Microsoft Windows Vista Home Premium SP1 32-bit for System Builders
$104.99
LG Black Blu-ray/HD DVD-ROM & 16X DVD±R DVD Burner SATA Model GGC-H20L
$104.99
Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
$89.99
TOTAL: $1166
